Will Ethanol Hurt the Duratec Engine?
premio53
Mazda CX-5
I've read the same thing, and it's going to be a disaster, starting with your fuel system.
Sent from the wrong side of the tracks.
Too much will Definately hurt. Running e85 in an engine not designed for it will cause a lean mixture and I imagine catastrophic failure is inevitable.
Unless the injectors in the vehicle are large enough to run an additional 25% fuel through them over what unleaded fuel uses and the ecu can adjust for it there will be damage. Do manufacturers do this on all vehicles? I have no idea but I'm not going to find out.
