Will BBS RK fit CX-5?
First I said yes, but then google seems to indicate they have a 61mm hub bore. That won't fit Mazda's 67.1mm hub (which is odd, for an aftermarket wheel).. You can solve that problem, but not without some kind of spacer or access to a machine shop.
I wouldn't mess with the integrity of something as important as the wheels.
Boring out the hub bore wont compromise the strength... Just have it done by a proper machine shop
^ This... If the integrity of the wheel is sacrificed by a few mm of center bore, then it is a flawed design from the get-go...
