Ceasar1010
- Mazdaspeed Protege 2003 and Miata STO 1997
omg I know that, let me try again
P0171 is a vacuum leak, look for leaks around the intake manifold and injectors and also the charge piping.
What color is the plug? Is the misfire intermittent?
I'm at a loss, someone told me to Sea Foam my intake and see if that helps. I wasn't to sure about that. I wish there was someone in Houston I could have come by and help me Diagnose. If I can fix this I am going to plan some time in the spring to remove my engine and rebuild it.
I honestly think your 02 sensor is done for. You can get a Bosch 17018 one for about a $60 ( I'm assuming you have an AEM Uego) I know it works for a fact because I'm running it as we speak on my AEM uego.I might swap 3 with 4 injector and see if the CEL follows; but could this problem make my wideband show pegged all the way to lean and never move?
