WHP versus crank HP
smp3000
Contributor
04' EVO VIII
Ok Ok, I'm sure this might be a lame-o question, but I've always wondered how they get the numbers for HP at the crank... I know if I dyno'd my car right now I'd probably be about 180-WHP and probably around 200 once I get to 8psi... But how does this transfer to crank HP?
Just a curious george! :)
Use the FM dyno numbers and see what the stock dyno run hp was then find the % loss by using the claimed 130 by mazda. Since FM got 90 HP that is a huge loss or just a bulls*** spec by Mazda. Using the same powertrain loss I got 180 whp would be 260 crank. basicly 90/130 = 180/X
I think he wants to know how they originally come up with the crank HP (the 130HP you mentioned). I would guess they just run an engine by itself, not in a car and not bolted to a tranny etc, and measure the HP based on the speed of the crank, not wheels.
Chris
