Who thinks the MS3 needs a diet?
2001 Mazda MP3
I Do... heres what i had in mind
tasteful light weight racing seats, (also will allow you to keep stock seats in great shape during storage)
CF hood, painted to match IMO
16X8 FD wheels,(for track purposes)
Take rear seats out (ditto on track purposes)
Lose crappy stock sub, replace with better aftermarket sub and box that can be taken out when at the track.
opinions please
I think it's fine...it still weighs less than my friend's 350Z and I can fit a lot more crap.
i actually really like having the weight...keeps this s*** on the ground.
also, the hood weighs a lot to prevent more torque steer
thats why i was thinking about using about a 245/16 or 245/17 to help compinsate for that. i just think a lighter car would be overall a better car, but please keep the opinions coming
i'm with you...i mean lighter...means faster, amirite?
if you're just going to counter balance losing weight in the front by putting more in the back, are you really doing anything?
and what's the deal with the sub? is the new one lighter? or heavier?
the hood would be a good choice. Coming from subarus with aluminum hoods, the steel hoods on these cars are INCREDIBLY heavy to me.
Also, don't forget the battery. A small racing battery could shave as much as 20 lbs from the upper engine area.
I don't really care about losing weight to make it accelerate faster, but the extra cornering response from losing front-end weight would be a plus as well as possibly better fuel economy.
It's improper to use weight for keeping a car planted. You should use aerodynamics.
just a sub better than stock, than when you go to the track you can take out. get what i'm saying? plus for every day driving you'll have better sub
I wonder if there's enough space under the jack on the left side to mount a small Odyssey battery. It would relocate the weight to the rear, shave off 20-30 lbs., and keep it hidden.
Lets not forget that the hood is designed to absorb a head-on impact. Carbon fiber hoods are nice, but what happens when you smack into something? They shatter and provide no impact absorbsion what-so-ever. I'm not willing to sacrifice safety to save 50lb. Aluminum would have been nice. I've had both a Miata and a S2000, which both had aluminum hoods and you could lift them with your index finger without a problem, but the hoods are obviously designed to crumple in a certain way whether they're steel or aluminum.
The MS3's weight isn't so bad. But coming from a 2700 lb 03 Nissan Sentra SE-R Spec V and a 2800 lb Mazdaspeed Protege, it could weigh less then 3100 lbs. If it did weight around 2900, it would be a lot quicker but I think traction would suck even more. It would also make the MS3 a lot tossable in the turns. Going with lighter wheels, suspension, C/F stuff and some gutting would probably get it to 3000 lbs.
opinions please
i betcha you should have bought a MX-5!!
can you take him in a race or on the track???
I came from an 05 350z that was heavily modded. But the comparison between the 2 cars would be somethign I'd like to know to see if its capable of taking a 350z say in a straight line race or even on the track.
The Z handled pretty damn well. at times it felt faster probably due to how lous it was and being lowered very low i could hear and feel the ground and the car's power more so maybe that was why it felt faster at times.
Can't beat the turbo sound of the ms3 tho, lovin it!
Braille Lightweight Battery/gt spec under braces/racing seat/cf hood/enkei light weight wheels about 15 lbs...rear seats/spare tire/jack....
that should shaved 150 lbs out....2900 lbs 300 + whp.....(wink)
Haven't checked to see what it's made out of, but a CF or Aluminum (assuming it's not aluminum already) would be nice for shaving some weight off as well as lowering center of gravity.
