Which OEM ENGINE OVERHAUL GASKET SET can i use?
Mazda Mazdaspeed Protege
Hi,I'm gathering up the parts to do a complete engine rebuild using forged internals.
While looking for the OEM ENGINE OVERHAUL GASKET SET.
What i noticed is that when i give my vin# to the dealership it comes up w/ part# 8MB410271 which is specifically for the 2003 MSP.
But in the post https://www.mazdas247.com/forum/sho...Protege-forged-motor-prepare-guide&highlight=
it says to use part# 8LB310271
And to add to that i found part# 8LB410271 on fleabay that says its compatible.
I plan on using the copper exhaust manifold to turbo gasket part# T25 SCE Gasket 9456.
Would that be the difference in gasket kits ie the other two don't have the turbo gasket?
Also will i need a different head gasket since i have .20 over pistons?
Thanks
yes, i think you'll need the cometic head gasket. Check signature for oem gasket set part #
