StormTrooper6
- 2006 Mazdaspeed6 Sport
Been looking everywhere but i can't find whether people are going with the normal raptor HID kit for the fogs or the "slim line" series. What did you go with? thanks for the help
Whatever you go with, find some that actually fit our fog lights without modification. The H11 bulb is shorter than what the DDM bulbs actually come as, which require you to break or modify the diffuser in the fog light.
What color are you going with?
I was hoping you would have already found one that fit nicely to help me out a bit in this situation lol. Did you get the slim ballast or the normal one for your HID fog kit? I will be going with the 5000K most likely. I like the temp of the stock setup just a hair more blue in it for me, I just want to keep a good amount of usable light. Hopefully later, way later down the road i can swap in the rdx projectors that block8head used for his retrofit.
Unfortunately my only experience has been with the DDM Raptor kit. It's got the smaller ballasts (the sizes are in a .pdf on the DDM site) and bulbs. I went with 6000k all around, and to me, match up best with the cool white LEDs that a lot of people put in their running lights.
Hey Steve do you or really anybody have a picture of how you had to modify the foglight housing to get the bulb to fit?
ur gunna have take the actual foglight out. meaning where you put the bulb in, you would have to take that out. Its held by 3 screws.
Then when you take it out, ur gunna have to stick ur finger in there and push it back and forth ( it may take some time ) until the metal breaks off.
Then grab some plyers and squeeze the metal from each side to make it small so it can fit through the foglight hole.
When ur done doing that, put the foglight back in, then put the bulb in and connect the ballast.
Turn ur car on and u should be all set
any questions, feel free to ask me
I've been eyeing this setup for a while... I'll make a decision after I see pics lol. I was a big fan of Tunersteve's setup to honest.
Hope to get some feedback when theyre in.
