- 2006 Infiniti M
s***, i drive it like i stole it. and im running from the ******* police
Red Baron said:The VERY best I ever got was 681km on a capfull tank. Yearly average is 8.49L/100km (27.7mpg US), and I drive mostly (95%) on the highway at about 105km/h, about 28000km/year. The P5 is a guzzler, no matter what you try.
Brian MP5T said:I stopped caring about Gas..
Red Baron said:Brian, if I ain't mistaken, in your case, with the money you've invested in your car, you have no right to worry about the cost of dino fuel...LOL! JK
hmmmm I have the software to plug into the obd2 port and watch the output; checking it is a bit involved for the home mechanic. you might just try replacing it, reset the ecu and see what happens. they tend to be pretty cheap, not a bad preventative thing to do.SNike05 said:I'll check the sensor but how do I know something is wrong with it?
GNO said:In addition to the spark plugs, check your vacuum hoses/connections. Also, clean off your MAF wires with electrical contact cleaner. If you're using an oiled air filter, some of the oil may have built up on the MAF causing inaccurate readings.
MyZmZm said:I have also done the A/C mod (so that the A/C isn't automatically on when you have it on defrost, etc). I can consistently get 30 mpg in the city; on the highway (if there's no head or side wind), I can get to 35-36 mpg.
