What's a good all season tire and rim setup for the CX-5?
I'm looking to purchase a set of all season rims and tires for my 2018 CX5, any suggestions? I was thinking 16 or 17". What type of offset is needed. I found most of the other posts lacking rim sizes, tire sizes and offset info. Im in Boise Id so I get a little snow and want to do some dirt trails fishing in the summer.
I picked up some used 17" CX-5 wheels off a 2017 for a 2019 GTR. I would have picked 16s but I worry about brake interference. Planning to put on some mild AT tires on there for this winter. I'm leaning Geolandar A/T G015. Good luck with your search.
I would recommend 17" just to be safe.
There's a lot of info in the thread below. Click on the link, then click on the Search button and change the dropdown setting on the right from "Everywhere" to "This thread". If you search for "17" you should get quite a few results.
What trim level is your CX-5, and what is the rim diameter, rim width, offset, and tire size currently installed?
The KO2 is a good all-terrain tire although it is a bit heavy. Another option is the Nitto ridge grappler which is a little more aggressive than a regular AT tire.
