What size bulb does the side marker turn signal take and ...
Re
TheMAN said:
you don't even own a 3, have you ever looked at it?
YOU CAN'T CHANGE IT
No i Dont own a 3 but my friends do and im pretty sure its a w5w.(cabpatch)
Re:
Yes you can access the bulb. You have to take part of the wheel well liner off on either side.You can access the bulb that way.(doh)
put down the crackpipe
you don't have to remove s*** to take out the sidemarker
YOU CANNOT REPLACE THE BULB
didn't I say that already?
just stop posting in this thread ok? you're not being helpful at all
In the manual it says that the side marker can only be replaced as an assembly. Can't change the bulb!
the man is right, you can't replace the bulb. and all you have to do to remove the side marker assembly is pop it out of place. i guess you could replace it if you cut the assembly open with a heat knife and soldered a new one in its place... hahaha.
