What needs to be done
Mazda SP20 2001
Hey ppl just bought a set of xxr 527 which are 17x8.25 offset +35 what needs to be done to fit them on my p5. Also what tire size should go with it . No rub or scrape wanted . Also my car is completely stock at the moment and will me lowering it when wheels are on. Thanks ppl
Given the fact that 17x8.25 is kinda a really strange size I cant even find a fitment for your car and I have the same car I am going to say you will need to do some wheel well trimming and honestly I dont even know where or how much. I would recomend fitting it to the car and writting about it to help others in the future but as stated before that is a weird wheel size and probably wont see many ppl running that size at all. really no need unless you are running drag tires but then you would already know you were goin to need trimming. Best guess is fit and run some trial and error tests. You may not need to do anything. when you lower it you will hit more bumps than now if you hit any at all.
16x8 +20, about 3 1/2 inches off the ground. would just a roll work, or do you think I would have the pull the rear a lot?
The tire size closest to stock height would be 215/40/17 and I believe they would be about 1" closer to the fender( that's with an 8" wide wheel b/c most calculator don't have 1/4 increments). I would suggest you measure. Here is a website I used ...
http://www.rimsntires.com/specs.jsp
