What is the sensor, just above the oil filter?
smetzger
03 P5, 09 Miata, 13 Fit, 09 Ody, 99 Civic
What is this sensor? Just above the oil filter...
Its leaking oil :(
Oil pressure switch/sender.
If it's leaking from the threads, remove it, clean them, and re-install with teflon tape.
oil pressure sensor, on this old of a car if its leaking just replace it its a cheap fix and you wont have to worry about taking it out later if it starts leaking again if you just clean it.
