Like the title says what is a BOV, what does it do, what are the benefits of it, will it void the warranty, and how hard is it to install ? GO to WWW.THERPMSTORE.COM to see the pix
CPE Blowoff Valve Kit for Mazda CX-7
CPE [2036] $289.95
Custom Performance Engineering, Inc., (CPE) is proud to announce the release of their Blowoff Valve for the Mazda CX-7!
When adding performance accessories to a turbocharged engine, a blow off capable of dealing with the additional boost pressure and discharge volume should be selected. Aftermarket blow off valves are typically much more robust and are designed specifically for high horsepower applications. The HKS Super Sequential Blow-Off valve is no exception, and CPE is proud to offer a complete solution based around this high quality unit.
The CPE billet adaptor is what enables this BOV to work on the CX-7. It was designed and CNC machined in-house using advanced 3D machining processes and high quality 6061-T6 aluminum.
The CPE blow-off valve kit comes complete with a high quality HKS super sequential blow-off valve, a CPE designed and manufactured adapter flange, and all of the hardware necessary for either recirculation or dump-to-atmosphere mode.
CPE [2036] $289.95
