AFAIK it is pretty much a driver's game. The 3 has the weight advantage while the 6 has the traction and added HP advantage. 0-60 the 6 should win, 5-60 (not using the clutch for 1st) the 3 might win. Around the track, well I don't know but I'm sure it is still a close call.elderlycoffee said:speed 3 is faster...
chuyler1 said:"Kind of" AWD? Exactly what does that mean?
CoachZed said:100% FWD until slippage occurs, with a maximum 50% rear bias as well as the (unconfirmed) rumors that it incapable of rear bias at high steering angles. In effect, it's a less sophisticated Haldex system, which is already not that great.
B1GHAM said:ok a few things. . .
CoachZed said:I went to test drive a speed3 and a speed6 at my dealer and didn't get any farther than sitting in the speed6 before I knew I couldn't live with it every day. The interior is really atrocious--it looks like Mazda made the dash from recycled milk jugs.
Add that to the extra weight and "kind of" AWD, and it was an easy decision for me. If I wanted a bigger AWD sedan it would be the Legacy GT, not the speed6 </flamesuit on>
CoachZed said:1) The AWD system can predict or extrapolate based on current data, but it can't see into the future. Delays and response lag are inevitable. Haldex VWs and Audi TTs have been doing this for years.
2) Even on a FWD car, it is entirely possible to get the rear to hang out. Drop throttle and throttle modulation can put the rear out on a well balanced car regardless of drivetrain.
3) Haldex is *not* necessarily quattro. Any AWD VW with a transversely mounted engine will get the Haldex system (e.g., AWD versions of the Golf and the Mk 5 Passat, but not the Mk 4 Passat). This extends to the Audi A3 and the Audi TT. The AWD system that Audi is legendary for, however, is the *Torsen* system that longitudinally-engined Audis (A/S/RS4, A/S/RS6, A/S8) get. This is not a FWD biased system. The Haldex AWD system is widely regarded as the inferior version of "quattro."
If all you're worried about is straight line traction in inclement weather, buy good sets of summer and winter tires and you won't have to deal with weight and parasitic loss.
ms6utah said:I've got both the ms3 and ms6 and the ms3 is winner hands down on speed but the jumping off of the ine i get from the awd in the ms6 is insane. tried a wrx didn't like it too much
