It helps ALOT...
75$ worth?
It helps ALOT...
ya ill take the links haha. heres a pic of the item http://www.mazdas247.com/forum/showthread.php?t=123778562
I just sprayed it. After reading a bit more, I am going to pull it out and disassemble it and give it a thorough cleaning.
Looking for some help. Yesterday my '03 P5 with 135k had the CEL come on. The code is P0300. I pulled the EGR valve and cleaned it out with carb cleaner. While inspecting it, I discovered it was stuck open. After cleaning it thoroughly, it remained closed. I also sea-foamed the engine. The CEL shut off for about 5 minutes and while test driving the car (post EGR cleaning), the rough idle and poor running engine persist.
While adding sea foam to the engine, I noticed a bit of smoke coming from within the engine cavity, almost immediately. I am going to inspect the vacumn lines after work today.
Any additional input anyone can provide will be greatly appreciated. My car has been flawless up until this point...
Utah? Higher elevation?As for MPG, I regularly get ~31+ on the freeway...
Above 6000' I get 36-38mpg
