Nice...I have thought about cutting into the cargo cover and mounting two speakers there...kind of like on the Hondas...
Here are the eyelids, no putty used (I tried it and it was a huge PITA). Critique away:
Besides the chip on the left side of the top eyelid in the last picture, they don't look too bad.
Please don't destroy your front stage by doing that. What you have now is perfect, just add more sound deadening!
Finished up my OBX header and MP3 ECU swap the other night. Stupid exhaust manifold bolts caused a bit of a problem, but after I finally got that finished up I was getting a rattle at about 1500RPM, turns out a heat shield a little farther back came loose!Took forever to figure out what it was...
Overall, I'm happy with the gains from the two mods, my idle is still a bit funky from the ECU swap, but that should even out in a couple days! I can definitely feel a difference in the power-band.
-Dave
which heat shield is it? i had the j-pipe heat shield fall off last year, and now there is another rattle under there.
I wasn't ignoring them, I tried the putty method and it didn't work so this is what I've got. I accept that you don't like it, thanks.
It was the small heat shield just before the second cat.. I really need to get it up on a lift, so I can take a little better look at it... But for now, no rattle...
Good to hear, I had been thinking of putting the JL's from the rear doors back there, but if you say don't, then I trust you...didn't know if it would make a difference or not, but I guess it would be a bad one...
Yea, Focals are active...sound great...not sure what exactly separate time alignment is, so I would say probably not...
