what does A-SPEC mean?
Minishotglass
03.5 mp5 5spd
i remember browsing through a website or tsb or something and i remember reading the meanings of A-spec, B-Spec, and C-spec. I believe they rate performance for something? Can some one tell me what exactly A-spec, B-spec, or C-spec means?!
uh.. i take it... J-SPEC is japan spec.... A-SPEC is american spec...? idk - chris
J-spec: Japanese Specification
JDM: Japanese Domestic Market
E-spec: European Specification
EDM: European Domestic Market
A-spec: American Specification
you get the idea
that works too :p
although Canucks sometimes get slightly different equipment
i beleive you read up on classifications for cars.
like on the mazdaspeed site they have an a-spec familia s-wagon with all the mazdaspeed body option, engine, suspension, etc.....i beleive b and c spec are similarly upgraded cars but without the full extension of mods done to A-class cars.
also, most american stuff is USDM. not adm or a-spec or whatever
A-Spec and B-Spec are just terms for levels of modification. Also refered to as Group (Gruppe) A and Group (Gruppe) B.
FIA regulations mandate the modification levels on these different cars.
Every car that participates in Group A racing has to be produced to numbers above 2500 units. Group N is 5000 units, and Group B is the lowest, at only 200 units, based on how much they cost to produce, due to the very powerful nature of the cars in Group B.
Group A cars are similar, nowadays, as follows:
- 4 wheel drive transmissions
- 2 liter turbo charged engines (there's an FIA 1.7 engine displacement multiplication factor for turbo charged cars) using a 34mm turbo restrictor
- Front mounted engines (longitudinal or transversal)
- Minimum weight of 1230 Kg
- Active differentials
Group A allows for the following modifications by FIA regulation:
- Full suspension geometry and layout. The original mounting points must be preserved within a 20mm radius
- Engine internals including camshafts, crankshaft, valves. Other engine components can be machined. The engine block must be preserved
- Engine peripherals (Radiators, intercoolers, ...)
- Engine management
- Braking system
- Gearbox, gear ratios, number of gears and gear selection type
- Differentials
- Final drive ratio
- Electric equipment
As you can see, there are few limitations. Group N is a little more restricted, and Group B is a little less.
WRC cars are generally modified beyond Group A standards, as well, but fall into their own group. Hope this clears some stuff up. =)
Basically, A-spec, B-spec, and so on are just different names for car modification levels in racing, in summary.
ok guys thanks for all your input, but i still spent like an hour trying to search on google or something.
this is what i found to clarify things. seems the "spec" system is somewhat mazda oriented.
http://web2.iadfw.net/theman/protegefaq/general.html
-----begin quote-----
What does the product line-up names from MazdaSpeed mean (A-Spec, etc)?
A-Spec is designated as "light weight" tuning part for street use. B-Spec is
designated as "high performance" tuning part which is further "tuned" from an
A-Spec part that is also streetable. The now discontinued C-Spec line is believed
to be "competition ready" parts (while maintaining streetability for Japan only) that
meant to be for every performance aspect of the car (and intended to be combined
together at once and used as such). The recently added R-Spec (parts which so
far are only made for the RX-7) is designated as "ultra high performance" tuning
part that is capable for track use however they are still streetable.
---end quote---
So corrct my friend. I hate it when people say ADM, where the hell did that come from.
i think you read up on theMan's site.
here is his info which is 100% more correct then mine =D
New Threads
