What are These on the Bottom of my Doors?
(See attached pics from bottom of passenger front door)
Maybe these are now a common items on newer vehicles - but I don't recognize these things found on the inside, bottom of the front doors - the white plastic item with what looks like a black flap over it. Can someone tell me what they are? Are they a switch of some kind? I'm just curious.
Thanks!
i wonder the same thing every time i towel dry the car after a washing
they are the drain holes. they have that little flap on them to make sure water can come out, but not come back in.
i dont know if they are standard on any other car, and i dont think they are new either - my 2001 protege has the exact same things on the door.
They are mostly standard on every car ive seen, Mazda's look a little different (a bit more fragile) but they all have the (supposed) one way drain plugs.
on much older cars, they weren't so fancy--just a small drain hole. It was usually the starting point for door rot...
on another note (pun intended) those flaps are also fingered as a potential source of buzzing when playing loud music...
