Buy better gloves.
the tubing is 3.5" dia and 1/2" wall thickness... so don't think that it won't warp... it will.
On stuff that can NOT warp(which is most of what I have welded unless I'm just practicing), I will just run 1 to 2 inch sections at a time, if you're doing a 2ft long section for instance... do about 2" of welding on the left side, then the right side, then the center... let it all completely cool(at least down to where you can touch it with a bare hand). then weld a 1-2 inch section at a time in-between the first 3 welds and let it cool again. Repeat.
For instance, I welded this front part of my bumper up over the course of about 2 hours IIRC. Did a few small parts, went elsewhere and came back 15 min later.
Gotcha. I've heard that time and again, and practice it, but haven't had to do much stuff so far that mattered, warpage-wise. I've read about applying heat to the backside, to warp it back to square, essentially, but haven't practiced it yet. I hear building boxes is great practice for that. I plan to build a bumper eventually for my Yota, so I'm sure I'll get plenty of fun trying to get that right.![]()
can you get a closer pic on them welds! i wanna see![]()
