Matrix2008
- Mazdaspeed 3 2011
First let me start by saying this is my first post here and i'm sorry if it is in the wrong spot. Also this is the first car i have ever modded in any way other then changing rims so sorry again if i get any terminology wrong.
I just revived and installed my order from James Barone Racing of a RMM, Power Path Stage 3 intake, and a SSP. Today is the first time have have taken it out other then a quick drive down the road to ensure it starts. Once i got out i noticed a weird noise coming from what sounds to be the front drivers side in the engine bay right where the intake goes. It only happens when in gear and i let off the gas. At first i thought it might be the BOV but in neutral i can get the BOV to hit w/o the noise so that rules that out. I guess it could be the RMM squeaking? Or it just might be the sound of the extra air going back out of the filter and it meant to be there? I am unable to describe the sound other then metal rubbing on metal(which isn't that grate of a description) so i took a video. The car has o be moving to produce the sound so there is some background rumble noise and the BOV noise, but you can hear it right before the BOV. Like i said, i just started modding and this might be something that is meant to be there, i have just never heard anything like it before. If you have questions ask away, i should be putting back on jack stands this weekend so getting under it to check something shouldn't be an issue.
Thank you in advance for taking a look,
Mike
Mike
