To anyone planning to utilize the J&S Safeguard in conjuction with the MPI Tuner, you need to know the following:
The 12v+ (Red Wire/Pin 4) on the J&S 2-Channel UltraSafeguard needs to be hooked into the Red wire(with the white stripe) that goes to power the fuel pump, and powers the Turbo Module (blue wire on the Turbo Module hooks into this wire). If you don't power your J&S with this wire, then you will fry coils when you have the key turned to on, and the engine NOT running.
