This past weekend I had to replace my damaged radiator.  My spal slim fans had rubbed through the core and caused a pinhole size leak.  Several other spots were about to rub through as well.
I am running 1 medium profile spal slim fan and 1 high performance spal slim fan. I chose not to use the cheap pin kits to avoid damaging the radiator (ironic), so I used several mounting brackets to securely hold the fans in place.
Apparently the excessive vibration from the fans took its toll on the core. This time around I placed flat rubber spacers around the edges of the fans. Hopefully this will remedy the issue.
The best solution would be to use a shroud to offset the fans from the radiator. However, I don't think any are available for my particular setup.
Just a heads up to save someone else a headache, and a little money!
