CheeseHelmet
I just got a OBDII scanner yesterday and I hooked it up to my PR5; it had one DTC code: P0660. The service manual says "VICS solenoid valve circuit malfunction".
I checked out the solenoid this morning and sure enough there's no continuity across it. The DTC doesn't cause the MIL to turn on so I assume it's not that serious but if something's broken I'd like to fix it![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So, how important is that solenoid? From what I've read, VICS is the system that manages those butterfly valves in the air intake, so does that mean that they're permanently open/closed without that solenoid?
Perhaps someone could clarify how the VICS system works in conjunction with the VTCS system, I can't really tell the difference between the two...
