Ventilation Kit for "smoking turbo fix"question
speed3mazda08
08 Mazdaspeed 3 Cosmic Blue Mica
anyone know what the differece is with the new valve cover to the old one? or have pics of the inside of the cover? i was wondering if i can just take a hose and run it down infront of the turbo with my stock valve cover? i have fabrication skills so ill weld on an extension to my PG TIP for the hose. or does anyone know the part nuber of the new valve cover? cause the kit is like $450 and i just need valve cover...i talked to my mazda parts guy and there is a new part number for my valve cover but not sure if it is the same as the one in this kit. any ideas?
"anyone know what the differece is with the new valve cover to the old one?"
http://i44.photobucket.com/albums/f31/bluezeal/IMG_9242.jpg
"i was wondering if i can just take a hose and run it down infront of the turbo with my stock valve cover?"
Not a good idea for a few reasons.
"any ideas?"
http://www.et-performance.com/turbo.html (Mini-kit)
I just added Krank Vent to my valve cover. I now have a vacuum in the crank case so no worries. Read the site for more info.
Having issue with oil in Intake, took out the Map sensor, this looks like it would work great, were is the second valve, I might be blind but I don't see it in Pic?
Second valve is supposed to go between the PCV and the intake manifold. I havent installed it yet due to the lack of access to that area. The second valve is redundant to the PCV and not as important. I may install it at the next oil change from below. Second valves job is to shut closed under boost and keep positive pressure out of the crank case (something the PCV is supposed to do).
