V3 triton installation help
03.5 MSP
I need help locating the positive headlight wire because this is supposedly the wire that dims the turn signals when the headlights are turned on. Thank you. I have a mazdaspeed protege
Hold on...what? Are you talking about the dimmer switch, the 12 V power wire leading to the headlight housing? Be more specific please.
Ok basically what I am trying to say is this. The v3 triton comes with an optional wire that makes the system dim when the headlights are turned on as to not blind the incoming drivers at night. I am trying to figure out what wire to splice into to make the system dim.
Ok, well what is the V3 Triton? Is it a headlight bulb, turn signal bulb? I'm not familiar with this product.
You could splice into the headlight wires on the dimmer switch in the dash, to the left of the steering wheel.
Depends how the led's are wired to work (do they dim when they see voltage or dim with an open circuit?), I wired my gauge to that switch to turn on the back light with the headlights.
you should be able to tie into one of the side marker wires. that way, they will dim when you hit the parking lights.
