Upgrade front disk brakes to 300 mm? Can I?
SEAL_BG
Hello to all..have a question. I drive Mazda 3 hatchback diesel that have 278 mm standard OEM front brake disk. OK i want to upgrade it to 300 mm, but my rims are 16". Is that a problem and do i need to change them to 17" rims or can drive whit 16".
Thanks to all that reply :)
It's the calipers that interfere with the rims, not the disks.
So it all depends on the size of the calipers you are going to use. 300 mm disks are not going to fit within the OEM brake caliper bracket. What calipers are you planning on running?
I want to know can i take 300 mm disk kit from any other Mazda 3 2.0 liter and install it to my car or can appear a problem like incompatibility?
I'm guessing you have a 2.0i Sedan. In that case, you'd need the 2.3S calipers, caliper brackets, S model pads, and S rotors (300mm). Hope that helps. Or you could just buy the Mazdaspeed3 calipers, brackets, and rotors. The Mazdaspeed3 calipers are the largest.
In the aforementioned six-car comparo, the Mazda 3 s was quickest to 30 mph, to 60 mph, to 100 mph, and through the quarter-mile. In that group, it also racked up the surest skidpad grip, the fastest lane-change speed, and the shortest stopping distance—168 feet from 70 mph, hip-deep in sports-car territory.
http://www.caranddriver.com/feature...feature/fourth_place_3a_2007_mazda_3_s_page_8
See if you can get the 2.3s calipers. The breaking distance is impressive
