universal map clamp. attn driver311
ok my question is will pt performances map clamp that i had from my srt4 work on my mazdaspeed3. the map clamp is one of the things i did not installed yet when my srt4 got stollen so luckly the bastard didn't get it but is it a a universal part. driver311 i know your running the pt map clamp will it all work the same. thanks.
yes it will work the same. good luck, just use the wire colors that driver 311 specified earlier. goodluck
thanks. do you know what everyone is tuning the voltage or clamping it at. i think driver311 said his was at 3.5 volts if i remember
Yes will work and just clamp it at 3.5v. I think thats 15.5ish psi. will work perfect. that test wire makes it hella easy.
