TWM gen2 short shifter?
EVADE
TEAM PRO 5 PRES.
Contributor
OPTION WAGON
hey, i just installed it a couple a days ago and does anyone have noises when then shfit not from the heat sheild but something else? also its kind of hard shift into gears? i got the kartboy bushings on to . i think this was already asked, but just had to ask again. does anyone have answers or the same problem?
thanks!
it's the kartboy bushings making the noise. Also give it some time to break-in and it will loosen up a bit and be easier to shift
did the problem go away for you?? i'm installing the same hardware as you, so i just wanted to know all the potential issues that may arise.. not sure what to look for in terms of trouble after installation..
Thanks..
I have the kartboy bushings and they make a quiet "hum" noise when I left off the throttle. It dies down over time. Is that what you hear?
Similar Threads and Articles
