Turn Signal Relay Help LED's
dtp03
06 Speed6 GT
Anyone know where the relay for the turn signals is located(06 speed6)? I looked in the owners manual and they don't label the relays. I'm looking to replace it with one to fix my LED's causing them to hyper flash.
I know I can just get one of the inline load simulators but I figured I'd try the quick in/out relay if possible first.
Also strangely enough if I use the hazard lights they blink at normal speed, only a single left or right turn signal is a fast blink.
I'd suggest just doing the load resistors, it's a much easier solution than messing with the relay. Also, the relays might void your warranty should something electrical go bad.
What tail lights do you have with LED
If my dealer is as picky about voiding my warranty as I've heard they will probably void it for either of the devices haha.
The reason I suggested the load resistors is that you can hide them in the rear under the tail lamps and they shouldn't find them unless their poking around back there. Otherwise, I wouldn't mess with the relays unless you know what you're doing.
I gotcha, I was just thinking the same thing as you for both options.
The resistors are cheaper anyway lol I will probably end up trying them.
A quick peek in the wiring diagrams shows that the only relay(s) that deal with the exterior lighting is the TNS relay, which does not control the turn signals. TNS controls Headlights, foglights, parking lights, and the headlight leveling system
It seems as though resistors must be used for a 6,CX-9, and possibly a 3. The turn signals must be controlled by the computer or something.
