ALRIGHT, I AM IN THE PROCESS OF ANSWERING YOUR PRAYERS!!
Today I ran to school (I'm a teacher, not a student
) with 2 washers, mind you I've run 4 since install. I am no professional but I've worked on cars a lot for a few years although this is my first FI. Don't take this as fact, but simply my first driving impressions.
Impressions:
It feels like it opens MUCH sooner. On 4 washers I am used to being able to lift off the throttle a touch and get it to give almost a stutter about a half second before opening all the way. Cool sound. Today on 2 washers it seemed like at the slightest lift it would open up all the way. It also sounded like it might be a touch louder and it is definitly more abrupt.
I floored it from 22 vac in 4th just over 2,000 rpms, there seemed like a bit more lag than I am used to. Starting from about 500 rpms higher and trying the same thing there was very little lag and felt like it always does. Conclusion? I'm probably looking for something that isn't there, it's probably behaving exactly like stock.
My
dashhawk (that what you guys wanted??
) said I was holding 16.5 psi in third gear. Can't remember what I used to peak at on 4, but I will checked later.
Well, I would say that I would drive home on 4, but I left the other 2 washers in the garage..... SO I am going to drive home on 2, swap for 4, and then go back out. I think this will ultimately be a better comparisson run anyway. I will post up later on 4 vs 2.
