Turbo'ing Questions
  • Thread starter Thread starter VizaX
  • Start date Start date
V
VizaX
Okay, I'm doing my own piece together turbo kit pretty much. I just want to make sure I know everything to get before I install it. BTW Im only going to be running about 6lbs until I have enough $$ for the AEM Standalone Nick and Andy are working on.
Right now I have the Turbo Manifold and Downpipe (Its the Spool V2 Tubular)
So everything Ill need will be...
1. Manifold
2. Downpipe
3. Wastegate
4. Turbo
5. Intercooler
6. Piping
7. BOV
8. Oil Lines
7. Vaccum Hoses
If I'm missing anything Please feel free to add to the list thank you.
Oh yes, the flanges on the Manifold are for a T3 Comp. Housing right? and what size Wastegate flange did the Spool manifold come with?
-jeff
fmu, so it can hold you till you get the aem. also eventually clutch. maybe a better fuel pump.
turbo(t3t04 or t25,etc)
downpipe(with o2 bung
high pressure fuel pump
SS oil supply line
SS oil return line with fitting in oil pan
intercooler(SMIC or FMIC, even water to air would do)
intercooler piping(bov fitting)
bov
wastegate(external or internal)
turbo manifold
all the gaskets
boost gauge
a/f gauge(better than nothing to say the least)
Map/Maf bypass(depends of which system from mazda)
FUEL MANAGEMENT UNIT(greddy, AEM EMS, APExi SAFC, etc)
FMU(not require if running a electronic fmu)
additional injectors(or bigger injector upgrade)
boost controller(optional but cool to have)
colder spark plugs(just in case they overheat)
edit: forgot a few things
fuel pressure regulator
Fuel pressure Gauge
List i typed earlier in mp3 forum
a type r should be fun to boost, becareful with the high comp. though
Extra injectors and an aftermarket regulator are not required if running an FMU and 6psi.
If you are building your own intercooler and are needing the core, we sell extruded core for the DIY(Do it yourself) guys.
o2 clamp. wide band, a/f gauge or exhaust temp gauge someting to monitor a lean condition you are about 29 min from andys shop andy is a really cool guy..
