Turbo XS SBE
dronizm5
2008 Black Mazdaspeed3
Hey I just got my Turbo XS SBE and I was wondering if anyone had problems with the install what to expect after the install and what I should have ready before I begin? Thanks and any input about this mod would be great. Also do I need to get a anti-fouler kit for this set up? I'm pretty sure that it said this setup comes with an extended bung to prevent CEL's.
That's my setup. An answer to your questions will require a lot of typing. lol. Search for my posts (or anyone else with dp mods in sig) and then let me know what else you want to know.
I am very happy with this set up and yes, it is a b**** to install any downpipe on this engine, but well worth it.
Extended bung did not work for me, nor did antifouler on the extended bung. I had to do the "diode fix" -- search for it -- again, hate to retype stuff already there and there is a lot.
you need alot of pb blaster, and a good 1/2" drive swivel socket with a few extensions to get to the bolts on the dp/turbo flange. Also, when you remove the 02 sensor take your time! they strip easy, you have to lube it alot, and as you screw it out a little you screw it back in again then back out again to work in the lube. put anti seize on everything that goes back on. It's not a bad install if you have proper tools- i did mine in a few hours alone in the garage on my back under jackstands.
