So I had some time on my hands ( cant sleep ) & while its not in great format, I hope this helps.
Basically there are three main wires from the timer, Right. So in the pics you can see the first red
Wire, splice into it & connect the blue wire from the timer. Then the other red wire right above it will take
The main red wire from the timer, splice into it. Last of the three main wires from timer is the
Green one, that will splice into the blue wire on the ignition
( there are two blue wires, it's the one at the top, same line as the main red wire you just connected.....)
It is a good idea to solder the connections ones its all working, if you dont over time the connections
May fail. Also dont forget about the ground wire ( there is a peace of metal right under the steering wheel, you cant miss it, find a screw that fits & use that as a ground..
First pic didn't come out great, but it says:
Green wire from timer to blue
Red wire from timer to red
Blue wire from timer to red
Last you may want to connect your speed signal wire ( this is the purple wire from timer ) this connects to the ECU ( pin # 58, I think, it's the green & orange wire )
Also a great idea it to connect the brown wire to the parking brake ( you can't miss it, it's the only wire connected to the brake, just splice into it )
Good luck man, I know it may seem like alot, but this is how I did it & it's works great for me........ Wish I had time to give you a better presentation.....
This is how it looks after all the work ( you can put it were ever you want )
