Truth regarding towing with the Mazda5?
Kojack
2007 GT "thing 5"
I have been reading about towing with the 5. Some say none, some say 1500 max. Anyone have the correct information? We have a sylvansport go trail/camper unit. it's 860 lbs, toss our 3 bikes and camping gear it gets to about 1000 max as we have all very lightweight gear. Can we pull this around in the summer with the 5?
All this said, I saw a 5 a year ago or so at a gas station with a 8ft pop up camper on tow behind it and the poor 5 loaded to the gills with gear. It did not look happy, but I think the camper had alot to do with that. I would say that camper was about 3000 lbs with 270 plus tounge weight. ha ha. Nothing like what we have....which is this.
If I towed with our CX 5, I would baby it every step of the way. Slow acceleration, no passing, let the car slow down going up steep grades. Drive 5 MPH or MORE under the speed limit.
Further, I would download the app the you can change the DD to show temperatures like transmission, oil pressure and ECT. Also change fluids more often than the book, oil, diffs, trans. Spark plugs are fresh, air filter is clean or new.
I tow about 10,000 pounds with a big box, 28' enclosed trailer several thousand miles a year. I do all of the above. My truck is powered with a Cummins diesel and it WILL start fast and NOT slow down going up grades. BUT it wears out the truck very quickly. Engine has never been opened and has 285,000 miles on it. First trans went 230,000 miles. The current trans will out live me. LOL
I have a digital dash with EGT, ECT, Trans temp, oil pressure and % engine load and others. If temperatures are going up, I slow down. I'd do exactly the same with a CX 5. When I get to the destination and unload the drag car, then we beat on this car. We know the truck will take us home after racing...
I change my fluids by the book for towing. NO EXCEPTIONS. The guys who cowboy their trucks and ignore maintenance soon have huge repair bills or stop towing.
Search old treads for detail discussions.
-US Mz5 is not rated to tow BUT overseas is rated for ~1500lbs
-Rear shocks blow easily (kyb monotubes), rear springs are very soft (helper spring), transmission is spec'd for Mz3 (ext. tranny cooler), stock brakes lack (panic) stopping power (MS3 kit), lower rear end is not reinforce (SOL). <-this applies to towing something really heavy.
What you want to tow seems reasonable and don't think you'll run into much issue at all. Just know you are towing with a Mz3, disguised as a minivan. Curt class 2 is the best hitch option; no 2" receiver avail.
We don’t have a lot of massive hills, our speed limit is 60mph/100km/h. I figure it would do it no issue. Our 5 has the hitch already installed. I am going to take the trailer without any camping gear loaded in the deck and see how it does.
You could get an obd2 Bluetooth device and use an app on you phone to watch and/or log various temps, trans comes to mind first.
I use the Torque Pro app. Now I have Mazda Edit I can watch and log rear clutch temps as well. Torque may have this pid, I haven't looked.
As mentioned earlier, you can get away with towing over the vehicle capacity by limiting speed and a soft right foot to the pedal.
While towing with a CX 5, I'd have a way to monitor ect, trans temp, oil temp, if we have it, and rear clutch temp. On a turbo, egt.
I monitor all the above, except for rear clutch temp, on my 2500 tow pig. When it starts to heat up I slow down regardless of traffic. Better to be a slow poke in the right lane than on the side of the road and having a very expensive tow bill and repairs...
I tow a kayak trailer with two boats and two bikes, maybe 400-450 pounds or so. Take it easy in the hills. I have an MT. (Not sure I'd want to tow a camper, even a light one, personally.)
If I didn't own a Tow Pig and wanted to tow a small camper I'd rent a truck. WAY less expensive than a torn up diff or trans.
Follow up on using a phone app. I use % engine load PID as my main yardstick for how much stress I'm putting on my vehicle. One could get an app and OBD bluetooth and watch engine load along with temperatures.
At the end of the day, I won't tow with my Mazda with these fragile, toy like, differentials...
Here is the absolute, total, complete, and unvarnished truth about towing with a Mazda5.
So glad America has so many lawyers looking for something to do.
That being said, I've experienced my 2015 M5 can reasonably tow my utility trailer with stuff for the EcoCenter or a bucket of dirt (2/3 cubic yard) on short distances.
You can definitely feel the dirt weight while accelerating/braking.
