Trouble with TWM shifter
Installed the TWM short throw shifter and bushings. Loved it for a couple days until I started having issues with the reverse spring. Sometimes it's either really hard to push the knob down to engage reverse, sometimes it doesn't pop back up coming out of reverse, like the spring is stuck. I grease the hell out of it with white lithium, but that doesn't seem to take care of the problem. Anyone else got that issue?
I haven't had this issue. Would recommend drilling down into the assembly and making sure there isn't some piece jamming up the spring or something.
Just FYI if anybody else gets the same issue: I called TWM and the gentleman - very courteous I must say - I talked to said I am (only) the second person calling about the same issue. Since I've had the shifter installed for just over a week, he recommended to let it break in for a few more weeks before being worried. Just be careful if the spring doesn't pop back up to make sure that the shifter is in 1st and not reverse (or vice versa).
