You base your ride quality on bump stops? Shocks provide dampening, but I've never heard of investing in a set of bump stops. Those things are only there for the occasional over-compression of your suspension. I didn't realize people relied on them for everyday driving.
Yes and no. I wouldnt say I base ride quality on bump stops alone but a proper set will enhance your overall suspension setup. Long bump stops mean less suspension travel, shorter bump stops allow for more suspension travel. So for OE bump stops, the amount that you trim is the amount of extra suspension travel you get back (if you lower car) which you have to be sure the shock can handle (Koni, Bilstein).
Also, it does not help that bump stops are progressive in design so when you trim off the lower end (top end is designed to fit the shock mount), you are cutting off the softer end and leaving the stiffer end so when you do hit it, youll get a nice jarring bounce. Aftermarket bump stops are designed to be shorter yet still retain some progressive nature and theres also the better material quality to further enhance its effectiveness. I would say the average car does hit the bump stop often like when going over a bump/hump, most movements at highway speeds (unless you drive on a smooth surface) as the forces will pull the car down and there will be less suspension travel.
Would you agree with the following?
All shocks have different compression (bound/rebound) rates?
-This is why it is important to match the proper set of springs with the right pair of shocks (personal preferences dictates as well). Youd have to look up specific shock compression charts to know what you are getting and compare that to the spring rate. This would affect when and how hard your shocks will hit the bump stop. Theres also the point that while progressive springs are more comfortable, they are sifficult to match with shocks b/c shocks are not progressive by design. Linear springs are more appropriate to match with shocks. The better shocks have the options of being revalved to your liking (comfort or aggressive).
All shocks have different effective ranges?
-If you put all of the different Mz5 shocks by different makes side by side, youll see that they are not all the same length. They are all valved differently and some have longer bodies and/or shafts, which leads some to think the aftermarket shock will raise the car. It is safe to assume that if they work differently then they too should have different stopping points.
All shocks will blow if exceeding its range?
-This is where the bump stop comes into play, to prevent excessive compression and also soften the rate very end of the compression. But if you use, for example, unmodified OE bump stops, which tend to be very tall, your shocks will not get to fully compress and work in the range which it was designed for and hit the bump stops too early. It would be great if shock manufacturers provide bump stops with their shocks but I can also image itll be difficult b/c of the various drops offered by various springs manufacturers.
These are my conclusion from what Ive learned from various suspension forum discussions. Some Miata folks are fanatical when it comes to suspension ("It's more fun to drive a slow car fast than a fast car slow). Ive always trimmed OE bump stops myself but for the Mz5, I am considering bump stops b/c I want as much comfort as I can get (for the kids) and still retain a sporty ride (for myself). However, $$ will always be a factor too.
At the moment, I am leaning towards H&R sport springs (progressive), Mz3 Tokico HP (cheaper) or Mz3 Bilstein HD (expensive but had them in the past and absolutely love them), and Fat Cat bump stops (they are listed as for MS3 so I am weary they may be meant for more aggressive use
