hm... but hm... hm... (haha) at 4000 RPM my motor "jumps" how is that a hesitation? lol
Im surfing around ShopKey5 right now and the TBS reads
"DESCRIPTION
Some customers may experience one or more of the following conditions:
-Whistle Noise from the engine compartment at idle.
-Engine speed is limited by fuel cut condition under high boost conditions
-Check engine light on with P0171 - Fuel Trip system Too Lean stored in memory.
The above mentioned conditions may be the result of a raptured waste gate actuator diaphragm. to determine of this is the cause follow the repair procedure as described below."
but i have the P0171 code, the shop i took it to said that it was the P0171 code. and it does seam like a fuel cut, i usually have the "pedal to the metal" so to say, when this happens, at at 4000 RPM's it might have a good boost pressure. and it tells you to replace your WGA.
(they (shopkey5) gived the job a 1 hour time limit to finish haha.)
If you want to check out shopkey5 i can send you a username and pass
i got something useful out of Auto Tech haha.
