F frito Member Jan 27, 2009 #21 For sure. I think that it is good in the 225/40/18 size also. However, others like the New Dunlap, Potenzas RE01R etc do not. I only mentioned it since I have two little ones and want to have the stock load capacity while I carve corners!
S sleeperstang199 Member Jan 28, 2009 #23 how does the 235 look on the rim? does it bubble out at all or is it a nice flat transition from wheel to tread? Also do you get any rubbing in turns or bumps with the 235?
