H3br3w_Ham3r
- 2008 Mazdaspeed3
17x8
245/40/17
On BC coilovers
Will it rub?
Have at it....
245/40/17
On BC coilovers
Will it rub?
Have at it....
With 245/40/17's on 17x8 +45, fronts will need a 5mm spacer and the rears will work. Just roll your rear fenders.
There was a local member on here who sold his car. He was running 17x8's with +50 offset on BC coilovers. His tires were 245/45's and had to run a 10mm spacer to clear the rings on the sleeve of the coilovers. a 5mm spacer was too thin. And I test fit some Enkei RPF's that were 17x9 +45 with 235/45 tire and I would need a 3-5mm spacer up front. And for the rears, depending how low you are, I still think you'll rub the fenders on bumps.
