Tire rub inside wheel well after lower
eoskolkov
mazda protege 5
So my protege 5 got 18inch 7.5 wide rims and smallest profile tires, and i also lowered it with tein s tech springs, and for some reason when i have some weight at the back and i turn the tire rubs against the inside of wheel well.
So what i though i could do is a camber kit to fix that but i don't know if that will make it worse or better. or is there any other things i can do?
yeah... put a wheel with the proper offset on... it's rubbing because the wheel's sticking out too far. I guarantee it's rubbing on the fender lip.
Then again, you could roll the fender.
