Tire pressure monitor being faulty?
jungleradio
MS3 CB
Hey there. I figured this to be an electrical issue.
I have an 08 MS3 w/ 4k miles and since I bought her new, the tire pressure warning light will blink for about 10-15 seconds and then become solid for about 30 seconds before the light turns off.
this has happened 3 times so far. after the first time it happened, i checked the tire pressure and all the pressures were fine.
the second and third times it happened (once was today), i didn't check the pressures at all. but the light goes out and stays out.
has anyone else had this problem or a problem like it? if so, what was/is/could be the cure? any ideas? thanks in advance.
-JR
