happy and angry
Says the guy who thinks the ECU busts out a ruler to figure out tire circumference, just gotta reset the thing.Google isn't the only thing that has failed you..
Not so much a specification nazi, really. I just want people to have all the information they need to make informed choices. I'm pretty anal about tires, though. Most important part of the car.
I wish I could find an article about potential problems with smaller circumference tires and the impact it might have on ABS/TC, etc. Anyone know of a good place to look? So far google has failed me.
That size is within ~1% of stock tire circumference, and won't cause any problems. 7% is a bit more. Stock tire size and stock tire/wheel combo circumference are different.im running 225/45/18's on my car and it has not affect the TC/DSC or my ABS from what i can tell, i know its not the same size as you said but its the same principle.
This is a good size, nothing wrong with it, it is very close to stock.
The issue is- numnuts wants to run a 215 35 18 tire on his wheel, this will fit but is 2 profile sizes smaller, ride quality will be diminished along with all the points made by the Canadian and 1 other fella. This is not good. Just because they are free does not make it a good deal. Granted they may not actually cause any issues but they are not appropriate for our application.
And, uh, just how exactly is it going to perform this magical feat?
I got a name, Texas.made by the Canadian
WTF man? "numnuts" was the one asking for advice on if it'd be alright. I'm the one that feels it's not going to be a problem. Call me numnuts, not the op. Sheesh.
But yea, if you're not gonna do it iBoost, I'll pay shipping on em and slap em on mine without a second thought. If there are problems I'll let yall know. lol
I was referring to iBoost, not you buddy, no big issue.
Okay. Let me be more clear. It's actually a 9% reduction in total diameter, and as a result a 7% reduction in total diameter.
You're right. I was just pulling numbers from here:Actually, a 9% reduction in diameter results in a 9% reduction in circumference. Since diameter and circumference are directly proportional, any increase or decrease would be by percentage identical.
Let us know when your shocks are blown and rims bent. This car shouldn't be running a 215/35 on these heavy stock rims. Our suspension is not designed for something that far off the stock size. On an MS3 they will feel like s*** unless you drive on smooth roads all the time.
I doubt he's gonna send me these for shipping only, but I fail to see how it has anything to do with the suspension other than there's less tire to absorb some of the shock. The suspension's not gonna be sitting any different. It'd be the equivalent of running more psi on the stock tire's as far as the suspension is concerned. And It's not like i'm going out hitting every pothole I see, sure it's gonna be easier to bend a rim by hitting something but come on. You act like I'd screw everything up if I were to put that size on.
The tires are part of the suspension. Running something with that much smaller of a sidewall increases what the the shock has to absorb over every bump.
