rentonmp3 said:This may be a stupid question, but i'm hoping someone may be kind enough to answer..
Are there chains that would fit the tires on my 2001 mazda protege mp3??
The tire size is 205/45R17 84V. I'd love to be able to take my mp3 to the mountains when I snowboard.
Thanks!!
BondoBob said:Well, it's not a stupid question, but...
Why? Check out tirechain.com or tirerack.com -- they may have your size. However, a wiser move would be to buy a couple of steel rims (15s are fine and if they cost more than 20 bucks a piece, keep walking) and buy a pair of snow tires for the front wheels.
Of course, the best move is a set of four, but two will do since by your post I'm assuming that the only snow you see is in the mountains, right?
Chains are a pain in the ass and if one comes loose it will destroy your nice little MP3 before you could pull over and stop.
Good luck and welcome to the board!
Bondo
kep0ne said:im not sure of your location, but i know that here in california, chains are mandatory in the mountains if there is a good amount of snow. if this is true for your area, you may be better off buying a set of steelies for the front (no winter tires) and getting chains to go with it.
rentonmp3 said:Should I buy just two steel wheels for the front or buy four? In any case i could either use chains or winter tires for the front wheels. I'm in the Seattle area by the way..
StuttersC said:If you can afford to get four, get four. Four snows are better than two.
The Protege is a FWD, so you can technically get away with snows only in the front, however then you start getting odd mileage intervals on the tires on your MP3 wheels. You'll have two tires that see summer duty only, and two that get year round use.
I would buy four steelies with snows and keep the stock wheels for good weather.
Having said that, I never bought snow tires while I lived in Colo. and drove everywhere, snow rain or shine, on the summer stickies w/minor issues if ever.
BondoBob said:Chris, when did you move to Ormond Beach? Are you working full time with Tim and the crew at GRM?
