Tire alignment & uneven tire ware
If you set the rear toe to zero, it will greatly reduce wear on the inside edge. I run more camber than factory, but still have even tire wear, mainly due to having rear toe set to zero, and running a quality tire. I am using Goodyear Eagle F1 GS-D3's in the summer.
Also, the quality of tire you use has great impact on how they wear. If you are running the factory 17's, and you are running tires that only cost $100-$120, well, you got what you paid for..........
And tires should be rotated EVERY oil change.
