I think its this...read
Meanwhile, variable valve timing delivers more torque and more power than a conventional engine.
To achieve the aggressive targets on improving torque, horsepower and smoothness, Mazda engineers focused on several other areas, as well. First was developing a new intake manifold. Using an array of powerful computer aided engineering (CAE) tools to compare various designs and options, engineers developed a sophisticated new friction-welded nylon intake manifold with equal length runners that incorporate new devices called swirl control valves. Mazda engineers fitted these specially designed control valves into each of the intake runners, close to the cylinder head flange.
These valves or "tumble flaps" in the variable induction system are controlled by a solenoid actuator and are closed during light-load operations, such as idling at traffic lights, shifting actions and deceleration, to maximize combustion efficiency, fuel economy and emissions performance.
The valves are fully open during higher load conditions, roughly 5,000 rpm, to maximize volumetric efficiency and power output.
The intake manifold is constructed of part-recycled material. Its design improved engine sound quality by emphasizing the even-order engine harmonics - a key to the equal length design.
perhaps mazda didnt remove it, thinking it gained us more power when its really bottle necking it..perhaps someone can buy an intake and remove it? I may try it, if nobody trys...
