Are u talking about the thing on the rear bumper
I just did the whole top of my car
I think you should camber the front more to match the rear. Poke is cool and all but it looks mismatched with the way the rear is
the roof? how did it come out as far as gloss? ive only used the matte finish wondering how the gloss compares to real paint.
Make sure your coilovers have camber plates in the front, then you will need the SPC camber arms in the rear to get more camber (depending on your wheel setup). Just make sure you get an alignment and they set the toe to factory specs, as incorrect toe will kill your tires (not camber).
Thanks! Yeah the coilovers have Camber plates for the front. I guess I'll order the camber arms too now. What about Spacers? I see some have different size in back and front. I was gonna go 10mm all around. Is that ok? What's the reason to go different sizes? Sorry but I'm a total newb to drop/slam.
If you order your wheels with the right spec, then you won't need spacers. Anything over 8mm requires bolt-on spacers or extended studs
