Levi, all that worrying about the offset and it was just misread. That's funny. These OZ's were quite the rollercoaster ride!
30 offset? Crap. Oh, they're 40, we're good. Hub bore too small? Oh s***. Oh, nah, they're good too.
I'm having issues with my ms3 now. I noticed it last night. I think I might have a boost leak because my gauge only builds up to 10psi in all gears (for max psi, normally 1st is 10psi, 2nd is 12psi, 3-6 is 15psi). Also, I hear more wind noise coming from the engine bay when I spool up the turbo. Also, the car feels slower and the boost builds up slower.
I did a quick visual test and checked the intake/tip to see if anything was loose, but it didn't feel like it. I'm going to take another look at lunch in daylight. I wonder if my BPV is leaking.
Check all the new hoses you put on from the intake install...You can also do a pen test or whatever on the bpv--it only takes 5 minutes to remove it and reinstall it. Hope everything works out for ya....keep me posted, I've still got the stock bpv you can at least try to see if it works better---although I do want to keep all my OEM parts in case it ever goes back to stock
Haha, well how much do you plan on selling your winter tires for? If it's less than $320, then damn lol. O well, I got some nice Blizzaks, 2 basically brand new. I still need to mount them.
I found the issue. It was the BPV. It wasn't on all the way, but only because the bottom bolt's head sheared off. My friend had a bolt that fit and somehow we got the old bolt stud off. I drove it on my way back to work from lunch and I was able to boost fine. I couldn't test max boost since it's raining and I break the tires loose too easily. The only issue now, is that the engine hesitates around 3-4k rpms when first getting on boost. The gauge shows the boost building to about 12-13psi, but the car doesnt pull until a second after.
I'm not sure how the ecu works, but I thought I read somewhere that it adjusts. So maybe if I pulled the battery wire off to reset the ecu, it might re-learn?? idk lol
I might have to try your BPV James. The gasket on mine was falling off when I first took it off. I didn't really see any tears in it so I just put it back in.
Oooo ic, well I'm actually kinda glad I got mine then. I practically stole them considering I paid so little. 2 have 70% tread and the other 2 have like 90%
Ya it's reallllly weird. I haven't touched it at all either lol.
It's more like a delay in power. I did some searching on other Mazda sites and I think it could be the ecu. If the ecu does learn fuel trims, it's possible that it got used to having the leak since I probably drove about 60 miles with it like that. Now that it's getting full boost, it might not be sending enough fuel for the increased airflow. This is just a theory though. I wish I had tools with me so I can take the negative off the battery. Also, I wish I didn't have to drive from Akron to Macedonia (30 minute drive) from Job 1 to Job 2, with only 30 minutes between jobs LOL. The hesitation/delay only happens when I get on the throttle. I didn't experience it in 5th or 6th. Maybe if I drive like a granny, it will be fine till I can get home.
Nate- I was watching that race live on Speed and was juuuust texting Phen then all the sudden I saw him on the tele. haha! I was like "Holy crap! That was Phen!".
Chipmunk- I would assume all our cars would like this colder/more dense air for the motor, especially you guys with top mounted intercoolers. Even my car seems to run better in colder air and I'm N/A.
And what's this talk about "winter gas"? What's winter gas? I've never heard of it? Do they put cheap fuel in the gas stations during winter or something?
Wow. I had no idea. Thanks for the info, mate. I run 93 octane all year long anyway for the MP3 ECU but is there anything I can do to find better fuel or any tricks I can do? Though I guess since I've been buying "winter gas" for years anyway I guess it can't really harm anything... Nevermind. heh-heh
