THe Hottest Red P5 Around
Maxx Mazda
Contributor
Stock P5
Got it cleaned up yesterday. Clayed and waxed with Meguiar's NXT. Check that shine! :D
So ya, under the hood, I've got to repaint the Strut bar cause I chipped a bit off, waiting on my PG catch can, and that VAC line going to the TiAL is gettin replaced. (Had my MBC in there, but not while breaking in the new motor.) Repainted the calipers while I had them apart (didn't just mask and spray...) Mods are WAY too many to list, but I'll try a few.
BRAND NEW SpeedCircuit built block (Arias / Pauter), Cometic head gasket, rebuilt head, JDM Cams, AWR oil pan, MSP oil cooler, 626 Intake mani, MAM / custom IC pipes, CS FMIC, HKS SSQV, SPOOL log mani, T3 60 Trim rebuilt with Turbonetics Stage III wheels, TiAL 38mm gate, custom 2.5" downpipe, mated to 2.5" Corksport Stainless downpipe back. (2.5" turboback) PWR radiator, AWR mounts all around, Perrin Fuel rail, WRX 440's, wrinkled valve cover, MSM oil cap, MAM vac. block, MSP revised welded LSD, GTX gear swap, revised synchros, MSP clutch fork and pin, FC throwout bearing, Spec lightweight flywheel, Spec Stage 2 clutch, KVR brake kit, Goodridge stainless lines, iON springs, Tokico HP's, Progress 22mm rear sway, MSP floor mats, MSP pedals (thanks to Pirana) aw ****... I could go on for quite awhile... Just look at some of the pics lol.
Some more.
And more...
Finally...
07speed3 said:
Great lookin car man!! What kinda numbers are you putting out?
Hoping for around 350WHP at 20psi on the T3. A bigger turbo is in the future, don't worry.
khaosman said:
Looking good :D Your break-in almost done yet?
Ya, 1,200 Kms to date, so I rip on it now. Bear in mind though it's still only on 7psi. Once the Haltech goes in (Start tuesday, but probably gonna take a week) then I'll go up to 8, 10, 12, 14, 16, 18, 20, 22, etc on the dyno as I'm tuning it.
You're a brave man. 10,000 km break-in for my engine, 0 psi for the first 2000 km, then 5 psi until 5000 km and 7.5 for the remainder,all on dino oil. Switch over to synthetic after that and then the boost will be increased.
I'm running Shell ROtella 15W 40 Diesel oil till 5,000Km's. 10,000 KM is WAY too long of a break in man. I consulted about 4 engine builders (2 of whom build 600HP CASCAR V8's at the rate of about one a week) and they said baby it for 500Km, change the oil, then start ramping it up in RPM (stil lstaying out of boost) but bring it right up to redline slowly then go down a big hill and let the engine slow the car right down (the more vacuum the better during break in) and then after 750-900Km's you should be on it pretty hard. If you're too gentle you'll glaze the rings, etc. Basically, how I understand it is that cylinder pressure gets in "behind" the first ring and pushes it out against the cylinder wall. You want this to happen as much as possible near the end of the break in, otherwise the first time you hit big boost you'll end up ******* the engine for good. They rebuild engines after about 2-3 races, and one they tore down after a test session (the engine was babied cause they were testing the suspension setup only) and then it was torn down and he couldn't believe how bad the engine looked inside because the temps were kept too low and the thing was never wrung out.
If you've babied it that long, I'd hate to think that you've ****** the engine, but it may be so...
aw s*** this dude crazy! :) Love the ride man
