- 2008 Mazda5 GT
The elusive 2 receiver hitch
I still cannot get over a 2 hitch and have been researching creative ways of getting one. Im aware of the cars limitations and legal implications so Im not looking for any debates. If you feel you must discuss these points, please create a new thread. Im NOT advocating this either. Im looking to see IF they fit, not whether if it is right or wrong. Im not looking to tow a boat (not that I have one) or anything out of beyond class 2 limits. Any other creative setup you may have come across is appreciated. I would also appreciate some input from folks who are familiar with class 3/4 setups on trucks.
From what I can see, the Curt hitch for the 12 appear to fit <10. IMO, it is the best option but also a slightly more involving install (cutting exhaust heat shield). Unfortunately it is still a Class 1 with 1.25 receiver. You can always get one custom made but due to the cars limitations, it would not be cost effective.
Option 1:
Thumbs up for human ingenuity! This is exactly what I was hoping to find. Unfortunately our license plate is on the hatch door and not the bumper else Id be all over this. Can still make it work on the Mz5 but youd need to make a perfect cut out and a trap door on the bumper (like SUVs) to cover the opening. Perhaps it won't be as bad if you weld the receiver on the bottom of the support beam.
http://www.golfmkv.com/forums/showthread.php?t=160121
Note that the poster took someone elses idea (mention in the post) and improved upon it greatly.
Option 2&3:
Another option is the CX5 Curt Class 3 (NOTE IT HAS CLASS 2 LIMITS, with a 2 receiver so it's not a true class 3!) or Reese Multi-fit (Im not a fan of Reese quality but these things are class 3&4). Ive looked under the car and took some VERY rough measurements and it seems a CX5 hitch may technically fit but may require drilling a hole (could not confirm). BUT, the issue is with our muffler. It rests directly under the unibody support beam so theres no clearance to mount the hitch to the beam. The CX5 has a center mount exhaust with dual tips so theres clearance on both sides. Assumption, this may partly explain why only light weight hitches are available for passenger cars as the muffler always gets in the way (from the hitch manufacturer stand point, not talking about the cars limitations). However, CX5 hitch may be plausible IF you also opt for a smaller diameter muffler. Going with a 7 oval universal just might provide the clearance on the inner beam to mount one of these! The 5 round universal will definitely provide the clearance. Assumption, I think the center mount dual exhaust from the 2.5 CX5/Mz3 should fit with some minor modifications (cut bumper + welding hanger +?) since the newer 2.5L Mz3 come with this type of setup. If going this route, there are aftermarket options from Racing Beat but Im interested in going there.
CX5 hitch. Yes, I realize there are other userful measurements I could and should have asked for.
http://www.mazdas247.com/forum/show...Measurement-Request-for-Curt-Hitch&highlight=
Underside of 2012 with curt hitch and ROUGH measurements from an '08. If someone here has or can get a 2012 Curt hitch and take the same measurements as the CX5 hitch, we'll know if they use the same mounts -or not. Seems pretty close to me
Reese Multi-fit.
https://www.amazon.com/dp/ (commissions earned)
Option 1:
Option 2&3:
Reese Multi-fit.
