seattleMS3
- 2008.5 MS3
thanks coyfish, ill consider those options. from what i did put down, what do you think i would be at (whp)?
I ran 13. 8 with ETS 3.5 top mount and MazdaSpeed cold air on worn stock tires and leaky boost. Also I cannot race the straight line worth a poop. With a decent driver mod and some good tires you should hit mid thirteens. I have the full exhaust and more tire and mounts and such. and now the car hooks up nice. It is really pretty inexpensive to get this car moving pretty quick. I will not report my times as i do not have slips but the car is much much, faster than when I ran 13.7s and .8s. tires and suspension,mm, actually helped the sixty foot alot. Which helps the elapsed time of courseyou are basically trying to do the same thing i am. i want around 275 whp, and to get my 1/4's in the mid 13's. what im trying to add is...
--test pipe
--TMIC
--rear MM
--plus the injen CAI i have already.
does anyone think this will put me where i want? or anything else i should think about? i want to stay away from mods that cant be taken out easily... aka TBE or turbo upgrades... thanks
